For this service, the dealer will likely recommend an oil change, brake and clutch fluid change, new alternator belt, valve check/adjust, maybe spark plugs, new air filter, and replace rear drive oil and transmission oil. If your bike is liquid cooled, they may also recommend a coolant change. (I have a 2010 which is air cooled.) What I did to save money is to provide the dealer with all of the parts/consumables, including the alternator belt, gear oil, motor oil and filter, air filter, brake fluid, etc. so that I was mostly paying for labor. That's what I did back in 2017. I live in San Francisco and it cost me $900 then but would be closer to $1200 or more, now. If you don't provide the parts, add a few hundred more.I just hit 36,000 miles so time for a service. Anything to watch out for based on your experiences?
Also what is your local dealer charging? I am in California.
Thanks
There’s no alternator belt on a 2015 and neither clutch fluid (mineral rather than brake fluid) nor coolant change are listed on service schedules.For this service, the dealer will likely recommend an oil change, brake and clutch fluid change, new alternator belt, valve check/adjust, maybe spark plugs, new air filter, and replace rear drive oil and transmission oil. If your bike is liquid cooled, they may also recommend a coolant change.
Yeah, don't complain about how it tastes or if the meat is chewey...I can’t imagine taking along my own consumables and asking the dealership to use them. Quahog’s dealer must be very understanding and desperate for work, as that would eat into their profit margins. Like taking ingredients to a restaurant and asking that the chef use them to cook your meal.
Let's hope so... It costed me almost € 700,--The 36000 mi / 60000 km is the mother of all service intervals 😭
I would never supply the parts for reasons mentioned above, and because the margin on parts is part of their profit model, and we do want them to stay in business. I do think its okay to do some service tasks ourselves however. I change my own oil but pretty much have them do everything else and they are fine with that. If you have done some of it just let them know.To Panzermann's comment, I don't think my dealer is desperate for work. But on a more important note, is it tacky/uncool to supply my dealer with the consumables in order to save on costs? My dealer has never busted my chops about that but I don't want to be a jerk either. What say the rest of you?
I don't know about uncool, but I would never try it, and I'm really surprised that there is a shop anywhere that would use customer-supplied fluids and such. They do guarantee the work, after all. However, I do use whatever lubricants etc. I like if I do the work myself.... What say the rest of you?
Two weeks ago, I was quoted $1200 for a 36K service here in TX. This was on the basis that the valve clearances were likely out of spec - had never been adjusted - would need the cams removed and shims adjusted. I was told the service would be less costly if the valves were within spec but the lower amount was not stated. I was quoted an extra $145 for a brake fluid flush. I proceeded to check the valve clearances myself (at 34,040 miles) and I found that six out of the eight clearances were well within spec while two were in spec but on the edge, on the large end. I am retired, I had time on my hands and I was interested to learn more about my R1200RT maintenance so I did not have the dealer do the 36K service. I did some work myself, including: engine oil filter and engine oil change; final drive shaft inspection and lube both splines; final drive oil change; spark plug change; top up clutch fluid reservoir; flush front and rear brake fluid systems. Doing this work myself caused me to buy the GS-911 so I could actuate the ABS pump during each flush and also reset the service light.I just hit 36,000 miles so time for a service. Anything to watch out for based on your experiences?
Thanks
Doesn’t everyone? 🧐But then I clean the calipers and compress the caliper pistons to change ALL the brake fluid
Ooooh … 👌… have full sets of Torx Plus bits
