Hmm, odd, I just don't seem to have any picture showing that side, I'll make sure to get one next time I'm in the garage
This is what I have, also at the end I have pic that really shows the width of that engine
Hmm, odd, I just don't seem to have any picture showing that side, I'll make sure to get one next time I'm in the garageOMG, this is so crazy, that it might actually work. If you have a chance, would be awesome to see the driveshaft side as well.
Ba ha ha ha haaahh!!! 🤪7 liter LS7 V8 in the latest Mazda MX5 Miata
Thomas, where did you find the electrical diagrams? I've not seen a source of them before.after looking at the diagrams
Yes, that is correct, 513HP @ the wheels 😉Ba ha ha ha haaahh!!! 🤪
Yeah, that's my conclusion as well, I think I'll just try to see if I can get the K1600 ECU fault code free.Thomas, where did you find the electrical diagrams? I've not seen a source of them before.
The transistor symbol such as that in the R1200R ESA indicates a microprocessor. The three leads in are positive, earth, and a LINBUS data connection from the instrument panel. As you say, the K1600 symbol seems to be a stepper motor, so there's a clear incompatibility.
It might need circuitry like an exhaust flapper valve eliminator (e.g. Healtech of Servo Buddy).I think I'll just try to see if I can get the K1600 ECU fault code free.
I know Touratech has some ESA elimination dongles for the GS series, I'll check and see if I could use something from them.It might need circuitry like an exhaust flapper valve eliminator (e.g. Healtech of Servo Buddy).
OK, what has been said here before was that they revert to the hardest setting, i.e. dynamic with passenger and cargo, I would presume that is closed in both directions then, or do you suggest they behave differently?I would locate different forks if not going to use the ESA electronics. The ESA fork is "dead" when not active, and kind of stays where it is... when off the damping valves are closed in both directions.
ThanksAwesome project. Looks like the hardest part is over, but hope you can achieve the looks, functionality, and performance you want out of it. By the way, that huge I-6 engine actually looks slim, compared to the ultra wide boxer twin. Ha ha. Good luck. And thank you for posting all that info
Considering the $$$$ spent already, wouldn’t it be more cost effective to buy an aftermarket manually adjustable set of forks!OK, what has been said here before was that they revert to the hardest setting, i.e. dynamic with passenger and cargo, I would presume that is closed in both directions then, or do you suggest they behave differently?
It was a real struggle to find a pair of fork legs to begin with, to the point that all I managed to find was a pair of RS legs that I put on my donor R while keeping the R legs for the project. The other alternative would have been to buy a pair of non ESA R legs, but I think those are even harder to come by than ESA legs, and buying them new aren't very cost effective at all.
That's an option of course, however, I don't know how much adaptation needs to be done to the tripple clamps, wheel, brakes, mud guard, ABS sensor and so on. Buying a pair of non ESA legs for the R1200R would obviously be the easiest swap. But I'll stick with the legs I have for the time beeing and see how they behave, and if I can find a way to cancel the ESA fault code. If they don't work good enough I'll look into this again.Considering the $$$$ spent already, wouldn’t it be more cost effective to buy an aftermarket manually adjustable set of forks!
I sold my donor R1200R last year, but I have a friend with a R1250R, I'll make sure to do that next time I see him on it@K1600R - see if you can sit on a 1200 or 1250 with ESA, just sit on it. Turn on the ignition, bounce the front end. Then turn off and try again...
Keep ‘em comming
Just managed to do this the other day, and yes, the fork turns very stiff with the ignition off, much stiffer than in the hardest setting with the engine running. You might call it dead as you said before.@K1600R - see if you can sit on a 1200 or 1250 with ESA, just sit on it. Turn on the ignition, bounce the front end. Then turn off and try again...
I think you will want to find non-esa forks... From what I learned at the MOA rally weekend before last (June 16-18) the front and rear are electronically linked, and require the computer and sensors associated. The front apparently tells the rear when it hits a bump, and both adjust thousands of times per second... It's called "dynamic" for more than just the expected riding style...Just managed to do this the other day, and yes, the fork turns very stiff with the ignition off, much stiffer than in the hardest setting with the engine running. You might call it dead as you said before.
So, I'll either need to find a way to electronically force the ESA in Dynamic mode, or I'll need a pair of non ESA legs![]()
