1 - 15 of 15 Posts
2014 BMW R1200R
I am thinking of getting a 28L top case (OE PN: 77437724352).
My question for anyone who has one: will a full face helmet such as the Shoei RF-1400 fit inside it?
Peripheral Input device Mouse Font Gadget
· Mark – Super Moderator
I had one on my F800ST and it readily swallows a helmet, although not much more.
A tip if you do get one - never lubricate the mounting rubbers with any protectant. They need to grip the rack so that in say a large dip, the force as the bike comes out doesn’t distort the locking mechanism under the case inner floor and cause the locking tabs to release. If this happens, you might feel a tap on your back and see a large ‘bowling ball’ follow you down the road.
Yep - I did this and it happened to me. I was very fortunate that BMW replaced the case free of charge. The replacement was subject to some cracking of the base with hard touring use that I subjected it to (rough roads) but I was able to ‘plastic weld’ the cracks and reinforce the base (all under the inner floor). I don’t know if BMW has improved the design in the meantime.
Tire Wheel Land vehicle Plant Sky
2014 BMW R1200R
Thanks for the tip!
No lube ✔
I really like that rear duffel bag. Looks durable and spacious. What is it?
Thanks for the tip!
No lube ✔
It’s an A-Bag (or AA-Bag?) made and marketed by Andy Strapz in VictoriaAustralia. Not a bad design but, being a fabric, I found it wasn’t fully waterproof so everything had to be packed in plastic bags. Also, the mounting strap was fixed so it was always a juggle to get the strap under the seat when mounting. I suggested a design improvement to Andy to add additional D rings each side. He graciously implemented this on mine free of charge but I don’t know if the enhancement made it into production.
I ended up selling it and getting a somewhat bigger Nelson Rigg Wet Bag - similar to the Givi bag but better mounting I reckon - positive metal grip clamps on the straps. It also has a good reinforcement panel to keep shape and not sag.
Tire Wheel Plant Vehicle Fuel tank
Reactions: pascalawag
Well, technically the BMW 28 litre top-case can hold a full-face full-size hemet.... but as a commuter I largely use my top case to carry my wet-weather gear and other bits and pieces. And when that stuff is in there, there's no way you can fit the helmet too. If you want to carry helmet plus wet weather gear etc., I suggest you go for a bigger volume unit from Shad, Givi etc??? I had a beautiful Givi V47 (47 litre) top-case on a previous bike and it could fit the lot (wet-weather gear, hemet, jacket)
Tire Wheel Vehicle Motor vehicle Automotive tire
The Givi V47 is my choice for styling, volume, build quality and weight capacity.
Plant Tire Wheel Vehicle Helmet
Black is very slimming, I understand.
That Shad model is clever.
The thing is there’s a lot of ‘shad’ on current BMWs. F800 panniers are std equipped shad, seats on a lot are shad. I prefer the style over givi and like my shad side generic casings are very low drag factor
1 - 15 of 15 Posts
