Do owners of the Classic model find that when you check tire pressure, it has lost some, and you have to add a little???
How often do you check your tire pressure?
How often do you add air?
Does anyone on the Forum use Nitrogen in your tires?
http://www.helium.com/items/100625-nitrogen-inflated-tires-pros-and-cons
How about Helium?
I'm serious. I know it sound crazy. Some think it makes a difference.
I have several Hondas with tube tires, and they always lose tire pressure. It isn't a valve stem issue, IMO, and new tubes don't change anything.
Maybe it's the kind of tubes. Natural rubber vs butyl. The thicker HeavyDuty tubes leak down quicker, and always needs to be checked.
BMW says;
Front: 2.5 bars Rear: 2.9 bars
That is 36 psi Front / 42 psi Rear set at 70F (21C)
How about Helium?
BMW says;
