1 - 11 of 11 Posts
I'm going to fit some grip puppies and it looks a lot easier to remove the bar ends to fit them than try to stretch them over.
Are the bar ends a simple unbolt/bolt job, or are there hidden issues like thread lock to contend with? And, finally, do they have a torque value for tightening, or is FT OK?
Cheers!
I just slid them over the bar ends. It was harder to get them the last inch onto the grip than to get them over the bar ends.
I've been toying with the idea of Grip Puppies on my 1250R. I had them on my previous bike, a FJR, and loved them as my hands are somewhat large, but it doesn't seem like the grips on the R are as slight in circumference as the FJR, so thus far I've left them alone.
I'm using cricket bat grips on my 1200-LC simply to prevent further wear on the original grips and to improve grippiness (no issue with vibration, for which Grip Puppies are designed, I understand).
‘Owzat!’ you ask? The slightly larger diameter took only a couple days to get used to, and I don’t notice it now - even switching from my SRX6. The extra grip means I need only a light touch on the ‘bars, which makes for better control. They are starting to show some weathering in the grooves, with surface cracking, but again, I don’t notice it unless I deliberately look at it.
Discussion Starter #9
Why not, Too thick? Took me couple of days to get used. Now it’s great.
Sorry for the late response. Yep, too thick. I gave them about 120 miles, but didn't like 'em. They only cost me £14 in a sale at Nippy Norman's so no great loss, especially as I have another use for the neoprene, or whatever it is
Try getting a length of cricket batt rubber from fleabay (about £2), this is about 1/2 the difference between standard and grip puppies. Have these on a couple of my bikes, only downside is they don't last too long so need to be replaced every year or so.
Discussion Starter #11
Cheers. Interesting thought.
1 - 11 of 11 Posts
