I stopped to get gas, after filling up, turned the key &.... click, click, click.... crap!
Wouldn't start.
Ok, guess it's time for a new battery!
Looked in the manual to get the part number for the battery, and in typical BMW fashion, no part number listed.
The manual says simply 12V, 14AH.
Um, a part number would be helpful!! That makes it easy to cross reference between manufacturers, and get the proper case size. I could have ordered the battery and when it arrived just do a one shot remove/install & be done with it. Doing research on the internet for 2012 R1200R battery yielded a few different results, nothing definitive enough to make me order one without looking at the existing battery first, I didn't want to have to return it.
Oh well....go take out the battery just to make sure.
The battery that was in there was a 12V 10AH, 180CCA! I guess the dealer I bought the bike from replaced it and decided to go cheap. What a shock! No wonder it always seemed to struggle a bit to start. The odd part is the battery looked as though it fit properly, and the hold down strap fit properly as well.
Yuasa lists a YTX14BS as the proper battery for the R1200R, but it's just over 1/2 inch taller than the battery I took out. hmm, that's odd, will it fit? There are two bolt holes for the hold down strap, I guess to accommodate different height batteries.
Anyway, after doing some research, turns out Yuasa makes a high performance battery -- GYZ16H, which is 16.8AH with 240CCA in the same case as the 14AH/220CCA battery they list for the R1200R. I had to do just a little 'adjustment' of the bracket to hold it down properly using the same hole as before, but otherwise it fit just fine. And, the engine cranks over & starts with ease!
Just some info in case anyone is looking for battery options.
Wouldn't start.
