Here's a picture of mine mounted by itself on my Classic.Good info. That looks like good bag for when you don't have your side cases.
I think I'll do the same. Did you only ever use two straps.? I had four on and found the most rearward straps the loose ends hang down infront of the indicators. With the pocket attachment I'm thinking four is overkill especially as I'm only carrying light stuff mostly.I agree, having had this bag on my last 12R. I just took a small thin black zip-tie and made a loop of it on the secure section of the strap, then just slipped the loose end into it once the straps were in-pace and tightened.. Snip off the ends of the zip-tie and bingo...!
I don't know what the capacity of my bag was (it was the smaller of the two sizes) but I travel VERY light, and it carried all I need for two weeks on the road last spring.
L of S
I only used the forward straps, being a light packer etc. I also went half a step further: I didn't like the fiddly concept of wrapping the strap around the frame member, so I screwed a hook into a nearby - but slightly more rearward positioned - threaded hole in the frame assembly (I think probably there to suit the fitting of pannier frames). Then I could just quickly and securely hook the looped end of the strap, tighten it, and all was very secure.I think I'll do the same. Did you only ever use two straps.? I had four on and found the most rearward straps the loose ends hang down infront of the indicators. With the pocket attachment I'm thinking four is overkill especially as I'm only carrying light stuff mostly.
From your pic, nardowell, I cannot quite make this out: on my (late) 1200 R - 2012 model - the small bag (and indeed the larger one) slipped onto the rear of the little rack at the back of the bike, secured by a sort-of sewn-in strap or sleeve underneath. The straps then secured it forward. It was well clear of the pillion seat hence gave no interference to my yoga-free 74 y.o. legs when climbing on and off the bike.The only draw back, and this would be true of many tail bags, is the ability to throw a leg over it.
Snap....so to speak as far as same bag, not the consequence of any leg adjustments to step through onto the seat. This bag is fine for size on a long weekend for me.BMW small tail bag.
'Scuse me, Erin, but reviewing your pix it appears you do not have a rack... :001_unsure:
L of S
If you want the bag to act as a back support, the installation used works great.From your pic, nardowell, I cannot quite make this out: on my (late) 1200 R - 2012 model - the small bag (and indeed the larger one) slipped onto the rear of the little rack at the back of the bike, secured by a sort-of sewn-in strap or sleeve underneath. The straps then secured it forward. It was well clear of the pillion seat hence gave no interference to my yoga-free 74 y.o. legs when climbing on and off the bike.
Have I missed something in your pic?
L of S
(Shortly after - I had a closer look at your pic: I think you have screwed-up the fitting of the bag! Read the instructions for further info on how to mount it as I described).
