Broken Wunderlich Seat - Help!
1856 Views 14 Replies 8 Participants Last post by  fireman
I have Wunderlich's really awesome Active Comfort Seat for my 2012 R1200R Classic. BUT, what is not so awesome is that it recently broke on the part of the seat that latches into the bike. I'm out of warranty and Wunderlich isn't going to give me another for free. Tried my own epoxy repair and it came right off again, and the broken off piece is gone. Anyone have a solid solution to this one other than putting a strap around the seat (did that)? Was thinking of a metal piece of some sort but I'm no fabricator.
Thanks!
112450
112451
See less See more
2
1 - 15 of 15 Posts
Thanks!
View attachment 112450 View attachment 112451
The first thing that comes to mind: you could try plastic welding staples (link #1 below to a kit on Amazon) to fix the cracks.
Additionally, if there is clearance between the seat and bike, put a metal mending plate (link #2) across the repair for reinforcement, using very short screws (link #3) or plastic/metal zip ties (link 4).
Without knowing the exact dimensions of the part that broke, hard to say how long of the mending plate you would need, if any. Considering a good portion of the riders weight affect this tiny piece of plastic, I would reinforce is as much as possible. If you do use a metal plate, predrill tiny holes for screws so that plastic doesn't crack when you insert screws. You may try to use plastic zip-ties as well, however those flex a lot. Metal zip-ties will stay in place, but are much harder to install (link #4 for something that might fit).
As for how to use plastic welding staples, just check Youtube - there is a ton of videos, and fairly easy even for a novice. Just test is on a piece of plastic drainage pipe (home depot has those) to make sure you know how much pressure to apply and how long to hold the staple in place not to melt a whole through.
Good luck!
EDIT: The above assumes that seat dish is made of some sort of plastic that can be melted. If the tub is thermoset plastic (can't be re-melted again), use a plate and bolts/zip ties. If it is fiberglass (doesn't look like it), you might have to look into fiberglass repair kits - I never tried those...
See less See more
Thx for tips! Mending plate would be good if there was a place to mount it - was thinking of a bracket where I could screw the ends into the plastic.
You may also try using a piece of metal perforate hanger strap: it is flexible, thin, yet strong. Easy to cut to length (use tin snips, angle cutters, or just repeatedly fold in one spot).
Master Flow Perforated Metal Hanger Straps-3/4HS - The Home Depot
Reactions: 1
Warranty or not, I’d first reach out to Wunderlich and see if they’ll assist.
Tried that 😞
I'd use something Bondix to get the broken piece into position, then I'd liberally cover the the crack with JB Weld Putty Stick epoxy.
Did you try contacting Wonderlich? There might already be a recommended repair procedure.
For the prices they charge the customer service should be exceptional :)
Tried that 😞
How is the repair going?
Sorry for delaying in my reply as I was away. I think I got a nice solution using 1/4 inch threaded rod and some locknuts. Simple and strong. Let’s hope the seat holds up OK.
112693
See less See more
Reactions: 1
Phew, that's good to know.......I was worried you had been sitting on it all that time as the solution to holding the seat down!
Reactions: 1
Glad you were able to come up with a way to fix it. And solution is very nice! I’m sure it will hold for quite some time.
Slightly wrong sub-forum, this is not an LC seat. By the way, I'm also in Weehawken!
It is a small world: our mutual friend who rides a Ducati GT 1000 Sport Classic just showed me a text message with a photo of your repair, and I’m like: “I recognize this seat! I was following this repair on the forum”. We just came back from a brisk 3 hour ride in PA.
1 - 15 of 15 Posts
