1 - 20 of 34 Posts
For some time, my RDC has been playing up:
  • slow to come up on the dash
  • occasionally dropping out (initially just the rear, then the front as well but not necessarily together)
  • occasional overpressure warning (pressure exceeding the maximum safe pressure 5 bar, I think)
A while back, I pulled the module and had a look inside – no evidence of any smoke having escaped.
My GS-911 indicated the sensor batteries were getting low, so I replaced them but it made no difference to the sporadic issues.
I'd been thinking in exasperation that I might pick up a used RDC module for a couple hundred dollars, but decided the other day just to have another look at the connector and apply some dielectric grease. Turns out I'd already applied some grease last time I had it apart so simply plugged it back in – this time pushing it hard, really hard, to ensure it's completely seated. And guess what – it's behaving exactly as it should! Finally ...
Electrical issues can be strange. There's been times in my life I've solved electrical problems without knowing specifically what fixed it. There are so many factors when troubleshooting that it's easy to forget what you've done. Or simply not being sure what is going on too. I end up talking to myself a lot.
112162
Recently had my rear tire replaced and for the first time, I am now having similar issues. Leads me to believe they didn't seat it right either. Did you end up removing the tire again, would suppose you would need to.
@home4sale2 - it’s the receiver module under the seat I’m referring to rather than the sensors. The sensors are sealed - no connectors involved. A tyre change should not impact on the RDC at all, so unless the fitter damaged the sensor, it’s likely coincidental.
Got you, thank you. If I recall, I had plugged the Hexezcan into one of the connectors, is that the RDC receiver or where exactly is it? Mine is 2016. Appreciate it.
I've had/have an issue with the TPM reading on the front tyre. The front tyre teaching is flaky and randomly dropping in and out for over a year and nothing electrical/ electronic was added. The front-wheel sensor was swapped out but no luck.
where exactly is it
It's mounted under the horizontal rail that holds the pillion seat latch. It's marked Shrader, so you can't mistake it.
@mikeS - like I said, try unplugging it, blowing out the connector socket/plug with compressed air, add a little dielectric grease, and push it home quite forcefully, with a jiggle for good measure. That might help. Hope you kept the old sensor as a functional spare ...
I shall, PZ. Thanks for the tip.
Location is arrowed by my pen
112164
Discussion Starter · #12 ·
Does it slid out or lift?
Depress the locking tab by squeezing the sides, and jiggle as you pull it rearward. Jiggle the connector plug, that is, not your booty … 😬
  • Haha
Could anyone explain why BMW calls a 'TPM' sensor a 'RDC' module?
112165
Discussion Starter · #15 ·
Reifendruckkontrolle. RDC actually stands for Reifen Druck Control.
Roughly, tyre readout control.
Reactions: GenlJuba and tima
Thanks.
Never would've guessed that.. except that it does make sense when you consider who makes them.. cheers (y)
went ahead, cleaned and greased both connectors (RDC to hex to bike). You don't get the satisfaction click with these connectors but I jiggled a lot (the connector) and appeared to have a faint click on both. Fingers crossed, will report after next ride.
The connector looks bone dry, PZ.
Discussion Starter · #19 ·
The factory doesn’t use dielectric grease on their connectors, Mike, but I reckon it doesn’t hurt to add a bit to help terminals settle into place.
The connector looks bone dry...
Thanks, PZ. Did you mention there's a battery?
1 - 20 of 34 Posts
