My ‘14 Camhead with 33k miles on it has a center stand which hits against the bottom side of the swingarm when fully retracted. This happens both when you roll it off the center stand and also on rugose roads making an unpleasant clattering noise.
It is a hard enough knock that is has made a mark on the swingarm.
The rubber stop on the left hand side of the center stand is still there and doesn’t look worn down. I’m wondering whether a replacement (longer) stop will suffice or if possible my center stand is bent and causing the premature contact.
Any experience with this problem that can point me towards the solution?
