Not a fan, I like the bike on it's original form, naked looks good.
In 2008 I was on the search of a new motorcycle, went to a BMW Ducati stealership in Charleston SC, mostly to see the F800GS but they had a Duc GT1000, what a nice looking bike.
DUCATI GT 1000
Engine
Type
L-twin cylinder, 2 valve per cylinder Desmodromic, air cooled
Displacement
992 cc
Bore x stroke
94 x 71,5 mm
Compression Ratio
10:1
Power
67.7 KW - 92 HP @ 8000 rpm
Torque
91.1 Nm - 9.3 Kgm @ 6000 rpm
Fuel injection
Marelli electronic fuel injection, 45 mm throttle body
Exhaust
Chromed, stainless steel exhaust system
Emissions
Euro 3
Transmission
Gearbox
6 speeds
Ratio
1st 37/15, 2nd 30/17, 3rd 27/20, 4th 24/22, 5th 23/24, 6th 24/28
Primary drive
Straight cut gears ratio 33/61
Final drive
Sprocket/ring gear ratio 15/39
Clutch
Wet multiplate with hydraulic control
Chassis
Frame
Tubular steel trellis frame
Wheelbase
56,1 in
Rake
24°
Steering Angle
32°
Front suspension
43 mm Marzocchi upside-down fork
Front wheel travel
4,7 in
Front wheel
Spoke wheel with chromed steel rim, 3.50 x 17
Front tire
120/70 - 17 with air tube
Rear suspension
Twin shock absorbers, with frontal cam system spring preload
Rear wheel travel
5,2 in
Rear wheel
Spoke wheel with chromed steel rim, 5.50 x 17
Rear tire
180/55 - 17 with air tube
Front brake
2 x 320 mm semi-floating discs, floating caliper 2-piston (30-32 mm diameter )
Rear brake
245 mm disc, 1-piston (34 mm diameter) floating caliper with sintered pads
Fuel tank capacity
15 lt (of which 3,5 reserve)
Weight
407 lbs
Seat height
32,6 in
Max height
41,7 in
Max length
85,8 in
Instruments
Electronic panel: speedometer, rev counter, warning light for low oil pressure, indicators for high beam, fuel reserve, turn signals, LCD clock, trip fuel, immobilizer.
I don't really know how I walked out of that place without that bike, but not much regret, I ended up with a great FZ6 for half of the GT's price, and now I'm a happy owner of Beemers version of the GT on steroids.
I'm still waiting for that 850 roadster they mentioned 2-3 months ago.
