TORRANCE, Calif., - LED tronics, Inc., announces energy-efficient, vibration-resistant T8 fluorescent-replacement LED tube lights that are ideally designed for display cases, coolers and cold freezers. The series LED60T8SM-360-XPW-001W 5-foot bi-pin LED tube light fit into standard G13 bases and are designed with a smaller tube diameter to accommodate the space inside food coolers and freezers and display cases. Additionally, the minimal lamp heat output of LEDs over that produced by incandescent lamps keeps temperatures inside the coolers and freezers optimally lower. As well, with their much wider ambient operating temperature and humidity ranges, the LED tube lights have a greater performance in cold freezer-type applications where fluorescents have high failure rates.
The 60-inch-long tube lamps come in clear (LED60T8SM-360-XPW-001W) and frosted (LED60T8SM-360-XPW-001WF) and operate on a wide input voltage range of 90 to 290 volts AC, thus accommodating both North American or European currents. They typically consume 21 watts at 120VAC, delivering a total lumen output of 1,950 (clear lens) and 1,798 (frosted lens) at color temperatures between 4500K to 5200K (pure daylight white). They provide a brightness of 668 maximum candelas (clear lens) and 527 (frosted lens) across a wide beam pattern of up to 140 degrees. Other viewing angles, tube lengths and a variety of LED tube light colors are available for OEM customers.
to more information about led tube light,please visit our website:LED tube,China led tube light,led Panel,LED Spot,LED Bulb,manufacturer and supplier- Zhongtian lighting Co., Ltd.
