1 - 10 of 10 Posts
These wheels are off my 2015 RNineT Classic and come with a set of TKC 80 Tires. I have been told they are the same wheels as the R1200R Classic except in Black.
They had about 8,000 miles on them when I took them off, neither wheel is bent and ride smooth, both wheels have normal wear, the spokes are a tarnished and front spokes have some rust; I think they me be able to be cleaned up but I don't have the time or patience. These do not include the rotors or ABS ring. Rear tire center is about worn out with roughly 1/32 on it, the front tire has about 6/32 on it. Front wheel bearings are included and buyer may want to replace them at their discretion however they were smooth. NOT interested in splitting the set.
REDUCED TO $450 - PayPal plus actual shipping in ConUS or pick up in SWFLA
110206
110204
110205
110207
110208
2020 R1250R HP
17x3.50 and 17x5.50? does anyone know if the rotors and all from a 1250 will swap on?
Do you have the weight to estimate shipping? Could you remove the tires to save shipping? I'm not interested in mud tires for my bike.
I suspect not, but check an online parts fiche for equivalencies as a start.
You might run into trouble with the rear wheel hub offset as it’s a completely different drive train, and tge drive is on the opposite side - don’t know it there are any directionality issues.
Reactions: Dirtmerchant
I saw a WC R1200R on a Facebook group that had been "Cafed" They put R9T wheels on it, these are marked directional and they had the arrow pointed backwards.... That said, I'm not saying they would work though, I'll see if I can find it again and post a link.
You are correct on the size, this is from MaxBMW Fiche
01​
36 31 8 546 290​
BLACK REAR WHEEL - 5,5X17​
14.31​
1​
$1305.11​
01​
36 31 8 546 108​
BLACK FRONT WHEEL - 3,5X17​
13.65​
1​
$1262.03​
@Pale Roadster, Not sure, but based on that name and the sellers name on facebook it looks like it could be the same person. I do not know anything about them or the bike other than they said it had 9T wheels on it.
1 - 10 of 10 Posts
