See if this link works.Could you post a link to the cap you purchased?
Don’t have electric keyIf you have keyless the electrical connector is on the left side toward the front.
Forgot about them being plastic.You'll need to take the tank covers off first.
Fuel Tank Cap for BMW R1200RT R1200GS AD 2013-2019 R1200R 2014-2019 Motor Black | eBay
R1200RT 2013-2019. R1200R 2014-2019. R1200GS 2013-2019. R1200GS AD 2013-2019. CNC Front Brake Fluid Reservoir Cover Cap Fit Ducati 899 939 959 1190 1299 New. Fuel Gas Tank Cap Cover For Aprilia RS125/RS250 RSV1000 Triumph Tiger 800 Green.www.ebay.co.uk
This gas cap doesn’t fit properly, plus no way of connecting fuel breather pipes. It was an experience taking plastic covers off tho.Could you post a link to the cap you purchased?
Thanks for replying.@D4VO There are usually 2 pipes - one that allows vapor pressure to escape from WITHIN the tank, and one that allows spilled fuel to drain from around the filler neck. The first is below the seal where the cap meets the neck - usually built into the tank to prevent leaking unless the bike is on it's side. These also both vent away from the exhaust, below the engine, to prevent major issues.
The cap you shared does not look like it should require that much disassembly - it looks like it just replaces the outer ring and center cap, so not sure why the rest of the system needs to come off.
