Remove the battery cover and disconnect the earth, connect your ammeter (set to mAmp) between the negative lead and the battery earth.
Remove the battery cover and disconnect the earth, connect your ammeter (set to mAmp) between the negative lead and the battery earth.I'm still trying to figure out how to measure any current draw. Putting an ammeter in line is not really feasible.
My preferable method of connecting a USB charger is directly to battery (fused!), so it cannot mess with the electronics or CANbus.Now the remaining question / mystery is: do I remove that usb socket to avoid any suspected battery drain in the future... I'll ponder that for a bit.
That's clever and should be obligatory on all chargers, also mains adapters...The Quadlock Smart Adapter has a USB-A socket and will switch off automatically once battery voltage goes below 12.7V, so no issues if connected straight to the battery.
Oh that's cool. I wonder if this is a mechanical on-off switch (one that really switches off the entire circuit)? I'm also a little baffled that the picture shows it in use with 22.3V??This switched USB plugs into the Battery Tender lead that most of us probably have. $15 US at Amazon and other places. View attachment 119815
Not really necessary on mains adapters I’d think - the voltage is either there or not.That's clever and should be obligatory on all chargers, also mains adapters...
Yeah but the keep leaking energy.Not really necessary on mains adapters I’d think - the voltage is either there or not.
True, but it sounds like it's worthwhile to try the battery before you spent 800 bucks on a "control module" most mechanics don't know what it does anyway.Just be careful buying a new battery hoping it will fix everything!
I completely understad your point. Hence how I wnet through 5 batteries to understand there was a much bigger issue!True, but it sounds like it's worthwhile to try the battery before you spent 800 bucks on a "control module" most mechanics don't know what it does anyway.
They would need to REALLY convince me that it's broke before I would have them do that.
