Hi,
I have a 2007 R1200R with a finicky instrument cluster. At times I would not get any life when I started the bike and ridden for a while. Since this seemed to happen in colder temperatures I decided to check the connection to see if cleaning and refitting it would help but it did not. The temperature in my garage was in the low to mid 50s Fahrenheit. I used a heat gun to warm the area around it and it came on. It would not come on again when it cooled back down. I took the cluster apart and it come on even quicker when warmed up.
Has anyone had this issue and found a solution to fix it without replacing the entire cluster? Your input would be appreciated!
Thanks!
Thanks!
