I picked up a used '11 R1200R and noticed a couple things with the instrument panel display. I was wondering if anyone else had similar problems.
1. The outside ambient temp display doesn't always update until I cycle through the other choices and return to the temperature. For example, when I turn on the bike it will read 77 degrees (when I know it's in the 90's) and stay there until I use the INFO button to cycle back to the temp it finally updates to the true temp.
2. The manual states that I should be able to display current MPG. I can only find avg MPG. Is this only an option on some bikes?
3. My fuel level was showing half on my way to work this morning, by the time I got there it shows a full tank. What are the symptoms of a bad fuel strip?
