Don't give-up! There is light at the end of the tunnel! It is an R1250R with a bunch of LED lights on it!!! LMAOGood heavens... I look at all these threads on upgrading lights on the R12xxR and I just have to shake my head in amazement. Why does it have to be so darn complicated? I mean, leds with fans?!? I could have sworn leds were running much much cooler than halogen, but I'm obviously mistaken. And complex wizard circuitry to avoid tripping the bmw sensitive feelings detector and all that jazz with error codes... Why aren't the engineers at bmw realizing that upgraded lights just might be a possible thing an owner might want to do?
I'm a relatively new owner (first year) and absolutely love my bike, but I've now given up on upgrading the lights, which I thought I wanted to do, but there's no way I'm dealing with all that hokus pokus.
Sorry if this sounds like just a rant (I guess it is)
Because BMW Motorrad designed it as they believe it should be. I’ve not yet seen an LED bulb that claims to be compliant with the various regulations - most LED bulbs and ‘work lights’ come with the caveat ‘for off-road use only’.... Why aren't the engineers at bmw realizing that upgraded lights just might be a possible thing an owner might want to do?
US Amazon still has these.any other seller? unavailable at the moment on US Amazon.
I've found this link for Italy: https://www.amazon.it/gp/product/B0BN64QJC2/ref=ox_sc_act_title_1?smid=ACBNYDB84Q97Y&psc=1
Yet they seem to be the older version.
@Ontrip I see some Yeungling Lager in the background... will do for a celebratory sip, yet still not my favorite. If you prefer something lighter than Guiness, I suggest trying Weihenstephaner ;-)Finally received mine and they have been installed but no chance for a test ride with winter and salty roads.
Very satisfied with the increased brightness for daytime visibility.
Three years in Germany with the best beers in the world and always came back to Weihenstephaner , preferably Hefe Weissbier properly poured into a wheat beer glass - crisp, delicious, nailed that beer itchWeihenstephaner ;-)
Has anyone tried these? If so, I'm extremely interested in finding out (a) if they are a true improvement relative to the stock bulbs, and (b) if they are truly no hassle with the hypersensitive BMW electronics. If it matters, my bike is a 2017 R1200R (and I have no clue if that's a hexhead ir bonehead, or if it qualifies as LC or not, the lingo just doesn't fit my brain). And of course I'm looking for plug-and-play, just swap the bulbs and smile.
Hmm, then I guess some of you are more tolerant than I would ever be about canbus errors. When I had initially read Fireman's post-install review, I gave up when I read about these dreaded canbus errors. I also wasn't too warm about the idea of the fans (I still don't get why LEDs need fans that halogens don't 🤔... what's the temperature of a halogen bulb when lit?).Yes this unit is the Auxito 2023 Upgraded H7 Bulb is the start of this thread
@fireman has done an extensive review and and I have also installed them and they check all of the technical boxes regarding installation and compatibility with the Canbus system.
His initial verdict after Road testing is very positive.
I’ve wondered about this too. A halogen bulb is ‘dumb’ - just a coil of resistance wire connected to the terminals, and designed to heat up with electrical current such that it glows ‘white hot’ (not really white). Conversely an LED bulb has semiconductors, which are not tolerant to very high temperatures. Hence the need for some cooling mechanism (large heat sink, and/or fan. I assume that’s the reason.I still don't get why LEDs need fans that halogens don't 🤔... what's the temperature of a halogen bulb when lit?
I was interested in that too. LEDs are not as hot as Halogen bulbs.what's the temperature of a halogen bulb when lit?
Well, the bulbs arrived yesterday and are now fitted. No CANbus errors so far, but they’ve not been switched on any longer than a few short runs to test the brakes post-bleeding - time will tell on that front.
Lovely white light, significantly brighter than the Phillips halogen’s and the spread looks good. MOT will be the acid test I guess.
You can try buying directly from manufacturer. Somebody on Facebook had luck purchasing from their website directlyshame: not shipping to Italy.![]()
