I have a relay connected to the high beam lead that activates my garage door, so I can open/close the door by flashing high beam.what happens if you toggle the high/low switch? is there a fix? why would someone do that?
that sounds cool.I have a relay connected to the high beam lead that activates my garage door, so I can open/close the door by flashing high beam.
I expect the warning disappears once the bike is started, so it’s a non-issue compared to the benefits of the bulbs.
battery voltage is not sufficient to clear CANBUS check. Alternator outputs higher voltage, and that allows to clear the fault. Essentially it is a non-issue.what happens if you toggle the high/low switch? is there a fix? why would someone do that?
I thought it better than the horn switch version - much longer life (for the rider).that sounds cool.
