1 - 8 of 8 Posts
Hi all, need a bit of help, I have a 2020 R1250R and I'm finding the indicator switch a little difficult to access without moving my hand over, it feels too low for me to use naturally. I don't like this as it takes my attention away momentarily from concentrating on the the road ahead.
I'd like to turn it round slightly so I can reach the switch with ease, unfortunately I can't see how it can be done, before I take it apart, does anyone know if there is a locating pin stopping it from being turned ?
I had the same issue with my 2018. It’s an odd position compared to my past bikes, but I got used to it in time.
I believe you can rotate the brake and clutch lever perches, but I think @Jussiboy is right - I think there are alignment pins that rest in a hole in the bar.
The signal indicator position is probably my only persistent complaint about my ‘20 R. I’ve had the bike a year now, and still have issues managing it intuitively...too far away and too low.
Would rotating the bars up help? Won't improve the distance from your thumb but my help with the height issue.
1 - 8 of 8 Posts
