Bear in mind that goes against what Michelin recommend.Mr. Badger recommends a Pilot Power front and Pilot Road rear here and here. What he says makes sense, the Pilot Power front works better and lasts as long as the Pilot Road rear so you can replace both as a set.
That’s a remarkable milage from a soft tyre.At that moment the tires were still OK, I think I can do about 8000 to 10000km with them.
Gareth I know what you mean but is is not the case with these Power 5 tires. These are NOT track-tires like slicks, these are normal street tires with a softer compound for extra grip (=fun).In that respect sports touring rubber will always offer more grip at moderate speeds, on cooler days and in the wet.
To get the most out of your motorbike's performance on the track, Michelin recommends our MICHELIN Power range of sports tyres.
I know. And I know why they say it.Bear in mind that goes against what Michelin recommend.
Interesting. I just bought my R1250R a few weeks back, and am scheduled to go to a 2-day track school in May. By then I expect I'll need/want new tires. Was looking at the S22s for the two days. Would you recommend them? Or would you stick to Michelin even with the two track days in mind?Currently running Bridgestone S22s because I was getting great deals and regular track time. As soon as this set is shagged I'll put PR rear, PP front back on it.
I've ridden track on both the S22 F/R and my fave Pilot Power front w/ Pilot Road rear combo.Interesting. I just bought my R1250R a few weeks back, and am scheduled to go to a 2-day track school in May. By then I expect I'll need/want new tires. Was looking at the S22s for the two days. Would you recommend them? Or would you stick to Michelin even with the two track days in mind?
Thanks, very helpful indeed. Was just in the garage looking at the bike. The lower trim panels scrape before the valve covers?If you have not already installed shorter thinner stiffer footpegs, removed the centerstand, and removed the lower trim panels to buy more lean angle the PR rear will be fine.
The huge, stepped in dog poop squishy OEM footpegs scrape first at street speeds. Replaced with Puig.Thanks, very helpful indeed. Was just in the garage looking at the bike. The lower trim panels scrape before the valve covers?
I will endeavor to learn from your mistakesWhat happens next is not as much fun as you'd think and served as a wakeup call that I was being foolish.
