1 - 20 of 51 Posts
Perhaps someone can shed some light:
I am in the US and recently bought a used (11,000 miles) 2018 1200RT (LC). I have the original detailed list of RT's technical features from the BMW dealer where RT was bought at. One of the listed features my RT was sold with and that is in question in my mind is: "Dynamic Traction Control" (DTC). In the US this option shows up on dealer's invoice as option #182.
My question: When I enter the RT setting menu what shows up in the menu is "Automatic Stability Control" (ASC). DTC option does not exists at all!!!! Even though the BMW manual does show that the two options are valid ones.
Again, I have a 2018 model and I am wondering if this is right. Is it possible that the DTC function is built into my RT and somehow simply has to be instantiated, by say, the dealer. Is it possible dealer simply did not provide this DTC option despite claiming to have provided it??? Am I missing something, misinterpreting something here?
Any light shed on my question will certainly be appreciated!
Thanks much!!!
On the Roadster 1200, DTC is part of the Driving Modes Pro (which gives selectable Road and Dynamic engine response).
Throw your VIN into an online decoder and you will see whether the Driving Modes Pro option was fitted by the factory. Or if your bike has the Mode selector button, you should be able to switch between the modes, confirming the presence of the option.
Reactions: dbyker
Hello Panzermann and thanks!
I know for sure I have “driving/riding mode Pro” as bike has those three optional riding modes.
Again, in terms of traction control my bike only shows “ASC” as opposed to “DTC” despite the fact that bike was supposedly sold with “DTC”. Something does not make sense here. Perhaps ASC and DTC are interchangeable terms. But on the other hands it appears bike’s operating manual distguish between the two. See attached figures extracted out of the manual. Thanks!
Panzermann,
I replied to your comments from yesterday (see below).
Guess my bottom line question is as follows: Should one be able to see both "ASC" and "DTC" as two separate and independent options in the setting menu? Once more: My bike only shows "ASC". It does not show "DTC"!!!
Thanks!!!
I’m afraid I can’t offer any further advice as the R has a different menu system to the RT. ASC and DTC are switched using a button on the RH switchgear, with an indicator lamp on the dash for each to show if it is disabled.
Notwithstanding the sales receipt, did you decide the VIN?
It is probably a question best posted in the appropriate section of BMW Luxury Touring Community
I have had a 2018 R1200R and now have a 2021 R1250RT but you need advice from someone with the appropriate model.
Have yet to run VIN by a third party. But yesterday, Sat, ran VIN by a local BMW dealer by me and service manager there generated a list of features bike comes with (my 2018 RT!!). One of those listed features is “DTC”. But than to my question why bike menus shows “ASC” and not “DTC” he answered that at some point BMW changed name of traction control from DTC to ASC. That didn’t sound to me like a good/rational answer (to be gentle….)
so we shall see….
thanks!
ASC differs from DTC in that the latter also uses yaw and bank angle measurements to detect rear wheel side slip and adjusts torque as required, allowing an amount of side-slip.
Maybe it’s just that with your version of firmware, DTC is not switchable.
112600
EDITED - I had them back to front. Thanks @sturgeon. 🤦‍♂️
Just thinking about it a bit, DTC is simply a refinement of ASC by adding the banking detection and yaw component. So switching off ASC also switches off DTC.
On the 1200LC Roadster, the ASC/DTC is switched using a button on the RH controller, with only an indicator light illuminated when switched off. There’s no option to switch only the DTC aspect off, and it wouldn’t really make sense to do so - you either want rear wheel slip control or not.
112604
I suspect the menu display on yours suits both standard and Riding Mode Pro equipped bikes - not worth implementing a change to show ASC/DTC instead of ASC in the menu for Riding Mode Pro equipped bikes.
DTC is ASC with inclination (lean-angle) sensor input.
Isn't that what I just said in fewer words? 🤣 🤣
Yeah - sometimes I just need to say things out loud before I get it.
My dear wife often has to remind me that thinking happens inside the head …
  • Haha
Reactions: dbyker and sturgeon
Discussion Starter · #14 ·
Got in touch with dealer who sold bike to guy from whom I bought the RT…. The service manager out there called me today and said something like: If “ASC” shows up under the “Setting”menu (switch on or off) that in that case and by default “DTC” is also an included option even though it does not show in the “Setting” menu. Have to say that it still not making 100% sense in my mind. My feeling is that I think that when they deliver the bike that either they did not instantiate “DTC” in bike’s Software (SW ) or Firmware (FW). I am still thinking to call BMW help center just to see how they are handling my situation/question…
thanks much!!!!
Is there an RT forum where you could ask the question, or someone you know with a similar bike?
Is the quote you posted for your bike? It looks like DTC shows up for N/C under the premium package. Do you have that package with E-ESA? If so, it looks like DTC should be there. It doesn’t make sense that this is a terminology issue.
And no forum member could go out to their bike turn on the key and check the menu to see if yours is the same as theirs? 🤷🏻‍♂️
I don't understand that statement. I am sure if the question were to be posted on the BMW Luxury Touring Community forum someone would check and give an answer fairly quickly. No one on this forum has the same bike.
There aren’t separate asc and dtc menus under the system menus on the r1250r as there appear to be on the ‘18 rt. On the r1250r, there is a dtc menu under the rider pro menu to set the mode for dtc. My manual refers to asc/dtc, which you can turn on or off with a button on the left instrument cluster. This conflating of asc and dtc is obtuse to me. The ‘18 rt is different; different left side instrument buttons and system menus.
1 - 20 of 51 Posts
