A word of warning to any of you about to embark on your first engine oil change on an R1200 / 1250 - this as you know is best done when the engine is nice and warm after a run, but when you crack open that drain plug (torx size 55) you better be ready with a large open container - SHE'S A GUSHER!!!
I discovered this to my detriment when my oil catch pan, that has a circa 25mm / 1" inlet and a smaller vent hole, simply could not cope with the deluge of oil and it went everywhere except into the catch pan! You need something like a 5 litre / 1 gallon fluid container with the top cut off to give the biggest opening you can get whilst maintaining maximum capacity - the bike holds 4 litres of oil.
The stain bottom left of the photo is after extensive cleaning......
Other than that, it is a very easy job to do and I always swap oil much sooner than recommended - it is the life blood and I hate to see a dirty oil sight glass and think of all that crud running around the engine!
