Hi everyone,
I thought I would share my new project.
The plastic pulleys on my 2011 R12R throttle body started to crack. I did not want to spring for the $400 aluminum replacements - although they look very nice! The Bing replacements looked like a good option, at a more affordable price, but I wanted something that was just plug and play and didn't require dissembling the TB or drilling/tapping. So... I designed a replacement that will slide on the metal portion of the throttle pulley and fasten with two screws. It will be made from SLS Nylon12 which I think will be stronger than the stock POM part. The POM part snapped to pieces way to easily when I was taking it off.
After a bunch of iterations I finally have something that I think will work and have ordered in my first two samples made of Nylon12 to test on my bike. I would like to sell these eventually, but need to test them thoroughly first.
Here are pictures of one of my final prototypes. As you can see I have beefed it up a lot from the stock pulley. The spring does touch the pulley a tad when the throttle is pulled, but I do not think it rubs enough to pose a problem.
Any thoughts/feedback is welcome!
