1 - 10 of 10 Posts
Hi,
Does anybody know if the rear shock absorber on the R1250R is the same as that on the R1200R LC - or at least whether the dimensions are precisely the same?
I want to upgrade my non-ESA rear shock but I can only find aftermarket shocks for the R1200R LC. They are not listed yet for the R1250R.
I’m pretty sure that the frames are the same so I guess the rear shocks are indeed identical, but does anybody know for sure?
Jack
You can check the AS Cycles parts fiche to see if the part numbers correspond, @Fazerboy
Reactions: Mr. Badger
Don't forget to report back :)
Discussion Starter #5
Well, if you mean report back as to whether they are the same then yes, the rear shock for the R1200R/RS LC appears to be the same as for the R1250R/RS as the part numbers are the same.
If you mean report back if and when I get an upgraded rear shock fitted, that may take a little longer. I’m looking at getting a Nitron R2.
Both, thanks (y)
Reactions: mikeyman67
Hi,
Jack
I changed my springs to Wilburs front and back a few years ago, Not a cheap exercise but excellent results . Assume they have for the 1250
Ted Porter provided a Tractive for me for my 1250R.
Like it very much!
JtL
1 - 10 of 10 Posts
