I'm thinking along those lines. I'm about to shorten the piece of wood I'm using to allow more manoeuvrability, and drilling it to ensure I can get it out again! I'm wondering if there's a factory tool for this job
I'm thinking along those lines. I'm about to shorten the piece of wood I'm using to allow more manoeuvrability, and drilling it to ensure I can get it out again! I'm wondering if there's a factory tool for this jobFor me, the biscuit maker was keeping the engine side connection aligned while putting it in place. If you can get it started and gently turn the shaft, it will eventually go on, but getting started is the pain. Might need something you can stick in to manipulate the universal joint once it’s in position so it’s aligned.
I have come across 2 different people saying that removing the whole swing arm is easier and less time consuming than trying to line up and seat the shaft while its inside the swing arm.. I have to replace the gaiter on mine soon and dreading the attempt. Good luckThanks for sharing. I'm aware of the snap ring and have put it to the back of my mind until I can get the UJ onto the shaft. When disassembling I was surprised that the shaft moved out without hassle from the snap ring.
