Hey fleuger99, does combined braking works only if you use only the front lever??Never had a problem with this. I also only use my rear brake at stop lights on hills as I use only my front brake lever to enable use of linked braking.
This is from my 2012 R owner's manual:Hey fleuger99, does combined braking works only if you use only the front lever??
thanks Darcy but,This is from my 2012 R owner's manual:
"Partially integral brake
Your motorcycle is equipped with
a partially integral brake configu-
ration. Both front and rear brakes
are applied simultaneously when
you pull the handbrake lever.
The footbrake lever acts only on
the rear brake."
Darcy
