Replace/repair foot peg rubber
3420 Views 23 Replies 9 Participants Last post by  home4sale2
On my 2011 R1200R the left driver foot peg rubber is split and starting to separate. I was hoping it could be easily replaced but it looks to be attached using a blind rivet. It seems like I have a couple options:
  1. Try repairing the foot peg rubber with rubber adhesive. (It's worth a shot.)
  2. Try replacing the foot peg rubber. In this case do I simply drill out the rivets and use pop rivets to repair?
I want to avoid losing half the foot peg rubber so any advice on dealing with this is appreciated.
1 - 20 of 24 Posts
You could choose either/both - the second if the first doesn't work.
If you choose to repair, fill the hollow in the foot peg rubber with silicon and leave it some days to set before riding.
The driver foot peg rubbers are held on by two screws ….easily replaceable….not sure why you would have rivets unless at some point the whole peg got replaced with aftermarket….I have replaced the rubber on both my ‘07 and ‘11 R bikes with OEM rubber pads…I think about $30
Sent from my iPhone using Tapatalk Pro
See less See more
On some models, they’re riveted - different internal bracket
Reactions: 1
What @Panzermann said. Mine has rivets.
Do I just drill these out and replace with (3.2x10mm) pop rivets?
Yep. I think 10mm should do it.
Reactions: 1
See my post with pics for the same operation on 2014 Camhead model: page 24, post #465 on thread link WHAT (minor thing) have YOU done to your "R&quot...
Good luck, ride on!
Reactions: 1
A couple of years ago I had a foot peg rubber start to break on my 2013 R1200R. I drilled out the rivets and swapped the front foot peg rubber over with the rear foot peg rubber, gluing the broken rubber together. I have not had any issues since.
The rear pegs are never used as I haven’t had a pillion on my bike.
Ken
Reactions: 2
Ken
Ken,
I didn't realize they were the same. Great advice!
Ken
Did you use 1/8" aluminum rivets? Any steel washers/backer plates?
Good luck, ride on!
It looks like you replaced rivets with 6mm bolts? Did you need new retainer plate for that or did it just thread into the (previous) rivet hole?
I remember it just threading in easy breezy.
New rubbers come with a new retaining plate. Depending on the model, they may have integrated nuts or not. If you are re-using a retaining plate, you'll need to go with what it had.
I thought I used 3/16" pop rivets on my F800 but the rivet heads on my LC look like 1/8". Drill them out and have a look ...
No additional hardware is required.
Reactions: 1
Thank you! Recommended hardware is 3.2 mm so call it 1/8" (grip length 10mm = 1/2").
I came across this when I painted my footpegs. My riveter wouldn't work with the recessed head.
I came up with this. I used JB Weld to set the nuts..
Automotive tire Automotive design Bumper Hood Automotive exterior
See less See more
I like that idea! I'm guessing once you have good tension on bolt the glue probably doesn't break free?
Thx JSnow !!
At first I used super glue and that didn't hold the nuts as well as I'd like. JB Weld set them in solid.
I used washers from 1/8" toggle bolts to fill the recess, then rivet tool made good contact.
No photo description available.
See less See more
Reactions: 2
See my thread: Foot Peg Mod
I purchased the peg lowering kit and moved the rubbers on to the new pegs by drilling them out. I used self tapping sheet metal screws to re-mount the rubbers but wasn't able to get them on as securely as they were. I also mount the bike cowboy style which stressed them more. I take my R off pavement quite a bit which is why I left them off and cut "teeth" into them. I haven't noticed much difference in vibration in good riding boots.
1 - 20 of 24 Posts
