I learned afterwards from a KTM 1290 Adventure rider at the car wash in Cowes that the best technique is to approach with enough speed so you can pull the clutch and coast through so there’s less risk of the back wheel pushing the front. He’d successfully crossed this particular causeway on the same day and saw a damaged bike nearby. At a Denman cafe that morning we were told of another bike that had gone down the day prior and we also stopped for a Tiger 1200 that had a cracked radiator from falling there - he’d also seen a parked up faller.@Panzermann I didn't want to be left out; if you could do it, so can I. I got going and stopped a couple of Ks down, a GS ride pulled up alongside looking quite annoyed and said he just went over on the causeway.![]()
I like the KTM man's advice, it makes sense to me, having had two slips on ice-like wet, short grass. The rear wheel does not like trying to transmit drive power, even the slightest bit, to the road surface. Whoosh! away goes the rear wheel in a flash.I learned afterwards from a KTM 1290 Adventure rider at the car wash in Cowes that the best technique is to approach with enough speed so you can pull the clutch and coast through so there’s less risk of the back wheel pushing the front.
The oncoming lane centre wheel track might have been a better option too as the algae seemed to be thicker on the uphill side.
Texas Hill Country back roads have a lot of low water crossing like that. If the water has been on the road for a long time it can get very slick from the slime and algae.Hydroplane? It seems doubtful that a slippery surface below that puddle would take you down. If I slow the replay down, it sure looks like the front wheel is pushed off the pavement.
I don’t believe I was transmitting any extra power - the front just folded on me, as it seems to have done with Mike. Any rev rise was due to me falling off the inside of the bike.… The rear wheel does not like trying to transmit drive power, even the slightest bit, to the road surface. Whoosh! away goes the rear wheel in a flash.
That explains my tip over @sturgeon:It's Australia, everything is upside down there.
No, no. We are at the top of the Earth. When I look straight up I can see right through the Exosphere. 🙃It's Australia, everything is upside down there.
the flat earth argumentDon’t know what you’re all on about …
No settle down lads and remember which way is UP when you next hop on your BMs, or is it down?
