This has started to happen on my R1250R with around 3500km. The first time I noticed it was around 1500km.
What is strange is that this happens when I try to change the damping with D-ESA button (rightmost switch on the left cluster, the one with the symbol of a shock absorber), which shouldn't have anything to do with DTC. The motorcycle in question is fully loaded: Dynamic ESA, DTC, ABS Pro amongst others. At first this occured on bumpy roads, so I thought that perhaps you need to wait for smoother roads for the damping control to have some "breathing space" before switching modes. But then the error occured at standstill!
The message is displayed instead of the "Road/Dynamic" and spring settings for a few seconds and then disappears. After another press sometimes it appears again, but most often everything works on the second or third try. The error is not described in the user manual.
The motorcycle will be in the shop on Friday anyway, since they will be installing the engine protection bars, so they will have a look at it. But until then: does anyone have an idea what this could be?
