T9 LED tube light is new generation tube of chip show, which is made by special different view angles mixing lighting design, without ultraviolet ray. High brightness SMD LED makes the light nicer. With inner high efficiency constant current driver, T9 LED Tube is brighter than conventional bulb. What is more, T9 LED tube has less decay and a lifespan as long as more than 50000 hours.
Main Parameter:
1. Power consumption: 9W
2. Length: 2 ft
3. Normal supply voltage: 100V-277VAC
4. Color of LED: Daylight White
5. LED Type: SMD3528
6. Number of LEDs: 144 PCS
7. Luminous efficiency: 670 lm
8. Housing Material: PC+Aluminum
9. Color Temp: 2700-3500K
10. Rated Lifetime: Over 50, 000 hours
11. Working Temp : -30℃~+50℃
Features:
1) Light source: high brightness SMD 3528 LED, emitting higher brightness at lower cost. the LED Tube looks nicer and more superior than traditional tube.
2) Good circuit design to get high power factor, over 0.99 on AC110V.
3) Environment-friendly clear PC cover and aluminum sheet housing ensures good heat release.
4) Energy saving up to 70%-80%.
5) Different lengths available: 60cm, 120cm, 150cm.
6) Color temperature can be customized.
7) Maintained free, no ballast or starter needed.
8) CE, RoHS, UL compliant.
Application:
1. Indoor use( living room / bedroom / kitchen room / washroom )
2. School / University / Hospital / Hotel
3. Conference / Meeting room /Show room / Showcase
4. Commercial Complexes
5. Factories / Plants / Warehouses / Offices
6. Super-market / Department store
If you want to know more about LED tube light ,please Click here enter zhongtian lighting,led light: China led tube light,T5-T8-T9-T10,led Panel Light,LED Spot light,AR111/PAR38/PAR30/PAR20,LED Bulb Light,manufacturerand supplier- Zhongtian lighting Co., Ltd.
Main Parameter:
2. Length: 2 ft
Features:
Application:
