ThrottleMeister makes so really SWEET throttle locks that function well, as well as reduce handle bar vibrations. I have them on an R1100S, & wanted ThrottleMeisters SOOO much on my new R1200R, because they are such attractive farkles. There are other throttle rockers and very functional throttle lock designs which would allow you to use SEXY bar end mirrors and handguards. I am currently using a large "O" ring. It works great! Cost me a dollar at the DIY shop. Grandaddy said, "Make DO with what 'cha got." I keep in on the Right side bar end. When I wanna' cruise, I simply roll it over to fill the crack beyween the bar end and the rubber throttle grip. Works OK. Not high tech or expensive, but quick & easy. When you get to a hill, you have to nudge the throttle open a bit anyway to retain speed, whether you have $150 ThrottleMeisters or a $10 rocker. Roll it back over to the bar end with the heel of my hand, and hit the exit ramp.
Here is where I got the idea.
Excel O-Ring Grip Kit
See the big one on the far right? That's the one! Like that.
Another variation is a larger O ring twisted in a figure 8 and doubled up, then scrunched up on the Right side bar end. The rubber seal ring off your old oil filter is just a bit tight, but stretched out a bit, works fine.
