I got my 2007 R12kR in 2011 as a private purchase. At the time it had 14000Km on the odometer and been serviced at the required 10k Km’s. First thing was to carry out a complete oil change on the engine, gearbox and rear drive using the recommended type of lubrication. I also applied new grease to the rear drive shaft and joint.
I made contact with BMW to confirm the service history. They could tell me that there was a re-call service letter on the bike which had not been followed up by the previous owner. I made an appointment and had the brake system upgraded free of charge, not bad considering the bike was already 4 years old – a tribute to the BMW service dept J.
Now to one of the sour grapes in this otherwise great motorcycle’s basket:
The engine emits a rattling/ticking noise from the right side as the engine temperature increases. I have checked the valve gear to confirm play and clearances to be correct, using the BMW RepRom DVD found on EBay as a service guide. Everything was spot on. I also had the right cylinder cam-chain tensioner changed without improvement. With the engine running on multigrade semi-synthetic oil at the time I changed back to the higher viscosity BMW spec mineral 20-50 oil without any improvement.
I did some further investigation online and found another possible cause; The right side throttle butterfly valve is not connected to any pot-meter and only follows as a slave. Without the pot-meter, the valve is suspended in a sleeve which will wear down as the Km’s stack up. This, allegedly, is the cause of the rattle.
Anyone out there who have experienced the same?
According to some German fellows you can remedy this on your own by purchasing “The TickerKiller”, see: http://www.boxer-design.de/en/detail.asp?ID=66&pID=581 (please bear over with the English translation, it’s VERY Teutonic!) which they claim will quiet down the racket and save on the shop expenses.
Anyone who have tried the “TickerKiller” or do I have to try it out by myself?
