An early start yesterday morning excited about spending the day amongst some of the Southern Highland twisties. All kitted jump up, on the bike, press start and no-go. Instead of the usual start-up growl, nothing, just a whimper. I checked, and the voltage was 11.2volts not enough to crank her over. Anyway, I pulled out the lithium jump-start battery back out my tank bag, connect to the battery terminals and back in business. This was the first time I used it on my LC, although I have used to others, but never my own. Most of the use is to recharge the iPhone, GoPro etc in my tank bag. Anyway, convenient multi-purpose device and takes up very little space (apart from the pesky jumper leads) well worth it. The only thing that used
Mike it looks like the control unit plugs into the battery pack by way of an Anderson-type plug. Have you thought about replacing the alligator clamps with such a socket and permanently attaching a similar plug to the battery?
I know it would make it a bit yarder to use your pack to help out a mate but I’d be happy to wait for you to swap over the leads to my bike should such an occasion arise ...
Thanks Mike! Looks like a great unit, but I am in the US, so not feasible to get that one.. Any other readers have a recommendation?
I have two both Kincrome not professional quality but good enough for a home hack user like myself. I like using the more substantial display unit that has an auto turn off the function.
@mikeS, seems Adventure Kings has been following this thread and picked up on all your tips and tricks ...
Mostly it comes naturally, but occasionally I put in the extra effort, Mike. 0You are soooo annoying - you are so consistent at being a pain the ar$e. Why me? I am so frustrated I could chew my leg off ...
Is that an aux battery on the left case hanger? Or an explosive device for ...?Gents, I have found this thread quite informative. I had also set out to build my own tool kit - see photo - but clearly I have taken a different, and in retrospect, the wrong approach. Major problem was finding an extension lead long enough when broken down at the side of the road. Also probably explains why I was unable to repair the bike anytime. Well the value of "group think" is obviously on display with this thread. If anybody wants details on the equipment on display please leave message,
I haven't seen one of those in years. Although I do recall seeing a large crank charge type at a boating store, but much larger. Very nice, PZ, no need to worry about batteries leaching out acid in your tool kit.I was tidying up in the garage the other day and came across this little gem, which I’ve added to my tool kit. It has rechargeable batteries powered by a small crank handle. So, come the zombie apocalypse (or COVID-19), when shops have sold out of AA cells and you're sitting by the roadside in the dark, @mikeS, I’ll just whizz away at the crank handle for a bit and, with sufficient lumens, complete that emergency ESA fork oil change.
On related note, at your prompting, I’ve thrown in a couple fuses and some zipties. I also junked the small shifter as the 14mm spanner under the seat does the mirror stalks, I’ve found. I also junked the 3/8 ratchet handle - I can get away with the T-bar, which is included for the rear wheel bolts. View attachment 107554
Nice. I wonder how those hold up. Without exception, every crank flashlight I’ve owned crapped out while in storage. Maybe it’s the battery having a finite shelf life if never used, but if a crank-powered device can’t be left in a box until needed, might as well rely on batteries.I was tidying up in the garage the other day and came across this little gem, which I’ve added to my tool kit. It has rechargeable batteries powered by a small crank handle.
This one's been in a drawer for years and is still fineNice. I wonder how those hold up. Without exception, every crank flashlight I’ve owned crapped out while in storage. Maybe it’s the battery having a finite shelf life if never used, but if a crank-powered device can’t be left in a box until needed, might as well rely on batteries.
