Tyre Pressure Sensor Wake-up Tool and Sensor Battery Replacement
18217 Views 44 Replies 12 Participants Last post by  home4sale2
If you have had to install new tyre pressure monitor sensors to your wheels
Your need your GS-911 and a 'Tyre Pressure Sensor wake up tool'
I used this, bought off E-Bay, cost 12 pounds, worked a treat :grin2:
TP Monitor System
Activation Car Tyre pressor monitor
made for SPX GM
Electronic device Gadget Technology Mobile phone Communication Device
See less See more
Reactions: 5
1 - 20 of 45 Posts
so, with that gizmo you can get your TPM to read without rolling? How is the GS911 involved?
Most people would have their bike to a BMW dealer to have the TPS replaced.
They would take the tyre off, replace the sensors. Once in place, tyre back on, pumped up, the bike would then be connected to the BMW computer.
A 'special' BMW wake up tool would be used, pressed near the sensor in the wheel, wakes up the sensor so information such as the sensors serial number is sent to the receiver on the bike.
This is done for the rear and same process for the front.
The bike needs to learn the new sensor, so on the bikes instrument dial, you then see the front and rear tyre pressure reading.
If you have a GS-911 and computer you can do the same.
The nearest BMW dealer is 3 hour ride away, and it means taking a day off work as the BMW mechanic does not work weekends.
The sensors for me are more cost effective bought from England.
There are a few wake up tools and they can be expensive...some don't work......this one worked and for little cost.
See less See more
Reactions: 3
Some have managed to ‘disassemble’ a sensor to replace the battery, rather than go to the expense of buying a whole new sensor.
Reactions: 1
Some have managed to ‘disassemble’ a sensor to replace the battery, rather than go to the exoense of buying a whole new sensor.
That was tried for the rear tyre pressure sensor, however you still need to wake the sensor up after replacing the battery.
The GS-911 people advise, if you let air out of the wheel valve quickly this should wake up the sensor, but it didn’t work.
Further reading, that method, has and has not for other DIY riders.
So did not know if it was a bad battery change or still the sensor at the time.
Bought the new sensor, but now I,ve a wake up tool, perhaps the old sensor will work.
EDIT: The wake-up tool is not required simply for battery replacement
Reactions: 1
So how long do the batteries last in the TPS?
TP Monitor System
made for SPX GM
Sometimes I need one of these to get out of bed in the morning. :grin2:
Reactions: 2
Depends, it can vary, time, heat, rotation, damage removing or replacing a tyre....can effect them from what I gather.
Reactions: 1
I'm having a problem with the rear TPMS sensor. Often I simply get dashes for a while, then it will 'wake up'. On my recent trip it triggered an over-inflation warning (pressure exceeding 50 psi - which it wasn't). Then the warning disappeared. Then the dashes re-appeared. In a word, unreliable.
I haven't seen a battery low warning, which is supposed to show as the battery gets to a critically low level, so I'm assuming it's a malfunction after four years and 76,000 km. No problems have been experienced with the front monitor.
Has anyone found a source of non-BMW replacement parts (they being excessively expensive)?
'Silence, was the stern reply' (to borrow a line from the highly esteemed Neddy Seagoon) so I've gone ahead and ordered a couple of Chinese sensors from Hong Kong. I may only need one for the rear (although eventually for the front when the battery goes flat and I can't be bothered digging it out and replacing) but there's always a risk of DOA and I'll be due for a new tyre by the time it arrives.
I also ordered a wake-up tool. The GS-911 functionality provides for entering the serial number of the sensor rather than usign a wake-up tool, but there's no guarantee the Chinese sensors will be labelled.
Sensors were about A$20 each and referenced the BMW part number. Wake-up tool was about $15.
Mick, as an example, I started getting the low battery warning for the rear TPS on the dash late last year (2018). I put up with it until I had the wake up tool in this post and a couple of new sensors from BMW Motorworks in the UK and timed the changeover with new tyres fitted earlier this year. All went well with the changeover and initiation of the sensors using the GS-911 and wake up tool. Assuming original TPS (have owned the bike since 2014), 8y for one of the TPS batteries to reach end of life. I saved myself a small fortune doing it myself, and reckon I probably paid for my GS-911 with this one action based on expected costs to get BMW to do it.
Thanks Peter, I'm assuming your bike is a 2011. That's not too bad I suppose, I've only had three punctures in the last 5 or 6 years and they've all been on my beemer rear wheel, the tps told me before I noticed anything so have been a good decision to have them fitted.
Mick, as per signature/footer, 2010 model ... last of the hexheads. Cheers!
Thanks Peter, if only I could read :wink2:
Reactions: 1
I got to thinking about the issues with my RDC today and decided to investigate further.
I've been suffering two error conditions:
- no reading from the rear sensor, just dashes
- an over-pressure fault condition for the rear tyre, with the bike thinking the pressure is 5.1 bar (which, of course it wasn't - normally about 2.9 bar)
The second condition has been annoyingly present for a couple of days, whereas previously it has come and gone randomly.
I checked it out with the GS911 and the fault indicated interference/lack of communication with the rear sensor. I presume if there had been a low battery condition at any stage that also would have been logged. The front sensor is working fine and research indicates the internal batteries should last about 10 years. So it looked to be either or both of:
- the rear sensor not switching in (or staying on) with wheel rotation
- a communication issue with the rear sensor.
I did consider a potential fault with the RDC control unit, so pulled that out and opened it up. There was no evidence of moisture ingress/corrosion as I'd seen on YouTube videos with BMW car units.
I turned the ignition on with the RDC control unit absent and the fault readout on the Nav VI showed an over-pressure fault for both rear and front tyres. This made me hopeful that perhaps it was a connector issue at the RDC control unit. I also pulled the ECU connectors and reconnected them in case there was a connection issue there.
I put everything back in place and took the bike for a test ride. The rear sensor over-pressure condition remained for a while and then disappeared, with the pressure reading appearing on the instrument display. I thought I'd cracked it, and gazed lovingly at that readout as I proceeded on my errand. I must have taken my eyes off it too long at one stage though, as the rear pressure readout had returned to dashes.
Hopefully I have cured the communication issue that causes the over-pressure fault and simply need to replace the rear sensor. As noted earlier, I've procured a couple sensors from China off eBay (they even have the BMW part number and Schrader embossed on the side ...) and when I get a chance I'll pop the tyre bead and swap the old one out.
See less See more
Further to my posts above, I haven't yet replaced the original sensors with the Chinese versions – the latter probably have flat batteries by now.
The pressure reading issue continued sporadically so I got thinking about whether it is one of the sensors (rear) or a channel issue with the RDC module. To isolate this, I got out the GS911 and my sensor wake-up tool and attempted to swap the sensor assignment front to rear (so when all is working the front should then read 2.9 kPa and the rear 2.5). I failed at this, not being able to work out how to achieve it before beer-o'clock ticked by. At the same time, I'd bought a couple tabbed lithium CR2032 batteries to replace those in either the original or Chinese sensors should I wish to.
Well since jiggering around, including using the wake-up tool on each sensor, they've been performing flawlessly. It may have been the threat of replacing the batteries, or the indignity of potential Chinese sensors being fitted to the bike that did it, or some kind of reset invoked by the wake-up tool – I don't know. But if yours are playing up and there hasn't been an instrument panel sensor battery warning, maybe try irradiating each sensor with the wake-up tool. It's cheap and won't harm anything. Let me know how you go.
See less See more
Reactions: 1
Not sure if this has been posted previously - attached is "HOW TO" replacement of RDC sensor batteries. Haven't tried it myslef
Do you think it would be worth soldering in a CR2032 battery holder to make future changes easier?
110478
See less See more
Do you think it would be worth soldering in a CR2032 battery holder to make future changes easier? View attachment 110478
I'd worry a bit about the battery flinging itself out of the holder at speed.
Reactions: 2
Folks, not sure if this is the appropriate thread but I have been suffering from the rear sensor intermittently "going missing in action" which results in the yellow triangle etc. This is really annoying as the tiny clock gets even smaller, and from time to time it would magically rectify itself. Anyway I did not get any low battery signal, but did a tyre change yesterday and replaced the RDC battery. Just be a little careful digging out the plastic resin. See photo's. Worth noting is that the battery is NOT a CR2032 but a CR2050. This means that it is 5mm in height as opposed to 3.2 mm in height. The hole for the negative side is recessed to fit the 2050. The 2032 looks like it is held up, so I made a small plastic disc and pushed it under the lower tab, to lift it up. Hot glued the lot together, (I used a match to hold the positive tab in place then snipped it off) and hey presto, both RDC reading fine over 30 mins ride. No need to do a "wake up".
I gather that the only performance difference will be about 30% shorter life, ie maybe 6 years. I think I can handle that.
110629
110630
See less See more
2
Reactions: 3
1 - 20 of 45 Posts
