First I've heard that – thanks Michael. I'm about to do my rear sensor in the next week or two.
First I've heard that – thanks Michael. I'm about to do my rear sensor in the next week or two.Worth noting is that the battery is NOT a CR2032 but a CR2050
Panzerman, if you are coming down to Tassie soon, why not drop in for a coffee, or a free bed if that is of interest. My number is 0418573815.RDC/Tyre pressure sensor battery replacement
The time came this arvo to fit new tyres in anticipation of a trip to Tassie in a couple weeks. I took the opportunity to change the RDC sensor batteries. Some time ago I procured a pair Chinese ‘Shrader’ sensors online as the rear had been playing up. Since reinvigorating them a while back with the wake-up tool, they’ve been fine, but with five years and 95,000 km under the belt, it wasn’t surprising that the GS911 reported low battery state. Rather than take a chance on the knock-offs, I decided to replace the batteries.
CR2050 batteries aren’t readily available hereabouts, and I wanted batteries with solder connections rather than rely on maintaining tension on the terminals detached from the original battery. I settled on PC mount CR2032 versions and fitted them using fly leads so that connectivity was by solder rather than simply contact. To further facilitate battery replacement in the future, I cut a piece of plastic from a yoghurt tub lid as a cover and hot-glued it in place. It only needs to be an environmental seal rather than hold the battery in place - the battery I chose fits snugly, and centrifugal force presses it against its mount, reinforcing its stability. Future battery changes when fitting new tyres will take only a few additional minutes, with no need to dig out glue or potting material, and soldering to fly leads is quick and easy.
Some tips:
The old batteries were a tad under 3V, the new being 3.3V.
- There’s no need to take out all the old potting material (incidentally, a flexible material, so easy to cut). Run a sharp edge around the perimeter (I used the can opener blade on my old army knife), cut across the battery in two places with a craft knife to release a strip across the centre, then use a small, sharp chisel to remove the potting material at the same level as the top of the battery.
- Lift the outer edge of the spot-welded upper (+ve) battery terminal and use needle-nose pliers to roll the terminal up to break the spot welds. Trim this terminal by about half.
- Prise the battery up from the edge opposite the +ve terminal (the battery is glued in place) and detach the spot welded -ve terminal in the same manner (pretty tight getting pliers in there).
- On the first sensor, I test fitted the new battery prior to folding back the -ve terminal, momentarily shorting the +ve and -ve terminals on the protruding +ve terminal of the sensor. This would have immediately drained some ergs from the battery, perhaps taking a couple years off its life. 🤦♂️ Fortunately it will now be an easy job to swap out the battery for a new one.
Removing the old rear tyre provided the opportunity to check out the Stop’n’Go tyre plug that’s been in place for quite a while now. Knowing the tyre was 90% worn at the time of the puncture and that I’d need to replace it before my next trip, I was happy to use it around town to get a bit more wear out of tyre. Looks pretty secure to me.
I've been at it for 2 hours. No matter how many clamps I use I can't get the lip of the tyre to clear the rear sensor. I've squeezed, wriggled, used some tyre levers...no go.By the way, even if you don’t change your own tyres, you could change the battery in your sensors. Simply break the bead on one side, use a large Irwin clamp (or similar) to squeeze the sidewalls together next to the sensor (or two clamps, one either side). This will proved sufficient clearance to access the sensor.
A wide vocabulary is an essential part of a motorcycle tire-changing toolkit 🤣🤣(Warning: swearing)
He does in other videos of him removing tyres by hand.I was also surprised he didn’t use anything to protect the rims from the levers.
Hi Mark, how are the 2032's holding up? I ordered 2050HR's (Maxell, look identical to the BMW sensor batteries I took out, seem legit, ebay, from China and Japanese made (this alone forces me to question the whole thing))...The problem is it's riding season and I am down for two weeks by the time these arrive! 2050s are hard to find, anywhere!RDC/Tyre pressure sensor battery replacement
Some tips:
