2281 - 2300 of 2318 Posts
3D printed a mount for my camera controls, angled so I can see it. The base is held in place by 8 x 8mm x 3mm neodymium magnets - sticks in place quite firmly but can be lifted off removed for maintenance.
Very clever! 👌
2012 R1200R
Put the 1200R away for the winter. Washed, waxed, and a conditioner on all the plastic. Oil & filter changed, gas tank filled and treated with stabilizer. I took all the bags inside to make a little more room in the garage. I also took the seat inside as well, it helps to prevent the vinyl from drying and cracking in the cold, also discourages mice from nesting underneath the seat. I'll continue riding on the V Strom until the snow and salt arrive.
Reactions: GenlJuba
2021 R1250R
As the temps dropped over the weekend, did a full spray and wipe down with ACF50 before the salt hits the roads here. Fitted new v2 MAM handguards as well to keep the windchill at bay. And swapped the oem headlight bulbs for Philips GT200s.
Adjusted the front camera so that both the fender and steering damper show, so I think it's good for now. Here's a short sample (camera saves every 2-3 minutes).
Good resolution on your system. I've had my Innovv K2 on my LC for nearly 2 years now and it's twice now once with an insurance claim and the other when a truck driver tried to run me off the road. There's more to this incident before this clip but you can get the gist.
  • Wow
Reactions: r0ckrat
2021 R1250R
Fitted the Wunderlich bracket to reposition my Quadlock wireless charger above the TFT. Very happy with the robust steel mount which also acts as a screen support. Now GoogleMaps sits where it should, and looks far better than hanging off the mirror mount like a Deliveroo food delivery courier! Upside is that the drinks holder is now where it needs to be too :)
Fitted the Wunderlich bracket to reposition my Quadlock wireless charger above the TFT. ... Now GoogleMaps sits where it should....
Yes, that's definitely the best position possible. I was trying to find that for my K27 with sportscreen. But there really is not enough space available behind the shield for this.I am hoping to run into a used higher screen one of these days. Then I will reconsider the mounting of my phone.
Fitted the lead for my heated gloves and vest. Now this weekend I can be toasty warm heading over Ortega Hwy on my way to visit my mom where she will be camping in the Anzo-Borrego N.P.
I made a heat shield for the left pannier to protect it from the exhaust heat. I am fitting panniers from a K1300GT that does not come with a heat shield.
The metal is from a cut off piece of stainless steel chimney pipe that was left over from when I installed our fire place.
This is what the OEM heat shield looks like.
Automotive lighting Hood Automotive design Bumper Automotive exterior
This is my DIY version.
Automotive tire Vehicle Aircraft Airplane Tread
Hood Motor vehicle Automotive tire Automotive exterior Bumper
Motor vehicle Automotive tire Hood Automotive lighting Automotive design
2021 R1250R
Nice fabrication, but I would have thought that aluminium would be a better material for a heat shield, rather than steel? Steel has a very low thermal conductivity compared to aluminium, one of the highest.
You did a great job.
Will you modify the K1300GT bags to fit your R1200R?
If that's what you're doing I hope you post more pictures in the future.
I've never noticed a heat problem on the exhaust side pannier on our R1200RS or R1250RS bikes.
Have others had a problem with this?
Reactions: GenlJuba
Looks like I'm confused. It happens a lot :)
The exhaust on my K1300S was on the right side.
I used my heated gear today, which warmed up the fuse housing for my power lead to all my other accessories, which then failed, so that's what I did to it today. Now need to run a new, heavier lead, with a better fuse....
Thanks Lee. The K1300GT exhaust is also on the right side, but there is no need for a heat shield as the silencer is long enough to expel the heat gasses past the point where it will become a problem for the pannier.
Tire Wheel Fuel tank Vehicle Automotive fuel system
The exhaust on the R1200R was also longer on the Hexhead models but with the Camhead they made it shorter. With the shorter exhaust I recall on my previous R that you could see the exhaust gas residue building up on the heat shield.
Hexhead with long exhaust.
Camhead with shorter exhaust
Tire Wheel Fuel tank Land vehicle Automotive fuel system
As for the panniers, no modifications or changes are needed, BMW used the same type of panniers on the R1200R, R1200RT, R1200ST and K1300GT (model year dependant). The only other thing I will do is to spray paint them.
2016 BMW R1200R
I mounted a set of Barkbuster VPR handgaurds. What a big difference such a low tech modification can make.
I was a bit apprehensive about it, fearing they would change the air flow in a negative way.
Not only does it reduce the air flow to my hands, it changed the air flow to the point I feel less on my upper torso. Which is a good thing. Glad I did it. 👍
photos, please!
