I have a 2016 R1200R and would like to protect the cylinder heads from meeting the ground. I was considering the Puig bars, but one review said they bent back when the bike was dropped at low speed. Anyone have any suggestions?
I just installed a set of the MachineArt covers, much better than the ones I had on at first, which I forget the name of...Do a search on engine guards/cylinder head protection, it's been widely discussed on here. I fitted these: https://machineartmoto.com/r1200r/2015-r-rs-liquid-cooled/x-head_lc/
Try this shortened link. Remember Computers are just high-speed idiots. I made a whole career out of deceiving them.Thanks. It's so odd, not only have I cleared browser history, I"ve tried 4 different browsers across two devices. These are also the only two sites, so far, that I've seen this behavior with.
I'm glad to be out of tech, but I still find things like this interesting.
Thanks all again!
I had the bolts just in the tread and not tightened. Then first tightened the "silent" screw/rubber block. So the bars were hanging from the silent screw.Looking for help, insights into the installation of the Wunderlich Sport Bars. I purchased them from Wunderlich America, and following the instructions I can't get the "silent" screw to be aligned with the bars. My bike is a 2016 R12R.
Did any of you that have the bars, have any problem with the installation?
Thanks
I had the same problem with my shad frames, just give it a bit of persuasion in a vice but don't forget to wrap a cloth around it first so as not to damage the steel/paint.Thanks for the reply. That is what I did, but the hole on the bar doesn't line up with the screw on the cylinder head. It is off by ~4mm (1/8").
The pre-2015 GS version fits your model - check out eBay or breakers/wreckers. Make sure you get not only the plate but all the hardware (brackets, screws, grommets threaded inserts) as these are expensive to buy from BMW.Hi Does someone know where I can find an under engine protection for r1200r year 2011 ?
